INSERT, UPDATE and SELECT data of cluster to/from DB
Hellow,
I have cluster of same data. This cluster/data I want save to Database. For this I use INSERT or UPDATE. Table column for this cluster is Binary type.
Problem:
I SELECT this cluster/data from DB, but is it OLE Variant type. In Variant Indicator I can see:
   OLE Variant
   Variant Type -> VT_ARRAY|VT_UI1
   Value -> Array(Non Displayable)
How can I convert OLE Variant data (array of U8) back to cluster of my type? When I use 'Variant to Data' with my original cluster LabVIEW return Error -2147352571 ;-(
THX
 JCC
P.S.: I can not use cluster -> XML because in this cluster will be LabVIEW types and binary data [Images, etc.]
(3,377 Views)
OK, thank you Vlado
We found solution:
I can convert may cluster/variant with 'Flatten To String.vi' to string. This string I save to DB.
After this string I can convert from DB Variant to string and after from string to original cluster/variant by 'Unflatten From String.vi'
It is working well. You can save to DB cluster with IMAQ Images.
I recommend use small table with 'cluster_ID'[int] and 'string_data'[text] ::: "Because SQL Server stores text/ntext columns on the Text/Image pages separately from the other data, stored on the Data pages, it can take more time to get the text/ntext values."
More details:
http://www.databasejournal.com/features/mssql/article.phpr/2212141
(3,351 Views)
