INI with HideRootWindow won't copy
I would like for a freshly installed copy of my compiled program to contain a line in Program.INI for HideRootWindow=True. I added the path of it's current INI with this option into the builder files section so it will copy the current INI file into the installation archive and subsequently place it in the install directory. However, after installing, the file exists but is blank... either it has not copied or LabVIEW overwrote it or something of that nature. Any ideas?
(3,041 Views)
Nothing specific, just a couple things to check. The name of the exe, ini and the first section in the ini must all agree. For example, if the application is called myApp.exe the ini file must be named myApp.ini and the first section in the ini file must be [myApp].
Other than this I don't know what to say...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,041 Views)
I was aware that the exe and ini names had to match but didn't know that it had to match the first section. At any rate my problem is somewhat unrelated... I will rephrase my question and repost... Thanks...
(3,041 Views)
