INCA (ETAS) and Labview Interaction using Active X controls.
Hello All.
I want to read ECU variables from INCA software to Labview..
Some info I got is, this is possible using ActiveX controls and COM APIs for INCA when both the applications are running on the same machine.
If anyone has worked on this before or have some idea request you to share some info.
The below link has some info but there the applications are running on two different PC's and communication is established over ethernet using ASAP3 protocol.
http://forums.ni.com/t5/LabVIEW/I-d-like-to-control-read-INCA-with-LabView/td-p/103254
But I have applications running on the same PC.
Request help in this regard..
Regards
Azhar
Message 1 of 1
(4,350 Views)
