IMAQdx Reset Ethernet Camera Address
Hello, I need help using IMAQdx Reset Ethernet Camera Address. The situation is as follows. The camera is in default state and its address is LLA ( for example 167.254.1.70), but the Ethernet port address is 192.168.20.1. I will try to assign an IP address using IMAQdx Reset Ethernet Camera Address, for example 192.168.20.100. If the camera is connected to the Ethernet port on the PC motherboard, the VI works. However, if the camera is connected to the NI 8233 card, after starting the VI, it ends up running with an Unknown GIGE Vision error. I am attaching an example of my VI.
Translated with www.DeepL.com/Translator (free version)
Message 1 of 1
(940 Views)
