IMAQdx GigE not robust at moderate CPU usage
A fairly open question, more a general request for information.
I am developing an application which is acquiring images from three Teledyne cameras, this is only a small part of the software.
I have been having real pain making the camera acquisition robust. Symptoms include:
- Sections missing from frames
- Entirely blank frames
- The actual cameras crashing and requiring a power cycle
My current understanding of how MIAQdx and GigE works is (Specific to a continuous acquisition using the acquire VI rather than a ring acquisition or a triggered acquisition):
- All UDP based
- Configure the camera to continuously stream image data over unicast
- Frames are split into chunks according to the set packet size, obviously this shouldn't be smaller that the network MTU. These packets are sent via a UDP unicast
- The IMAQdx driver is constantly monitoring the UDP port the image data is coming in on, and assembling the data into actual images and storing them in buffers
- Using the acquire vi I can copy the image data from the specified buffer to an IMAQ reference
Things I have done to improve the situation:
- Jumbo frames (I can't do this because our system will not allow for it, I am aware of why but it is an inordinate amount of work to correct it)
- Set desired peak bandwidth to 333Mbps for each camera (I understand that this determines the interpacket delay but have been unable to find specifics of exactly what this doing)
- Network card Interrupt moderation rate set to minimal
- Increased network cards receive buffer to the maximum value
- Ensured that frame rate is set low enough so as not to utilise more than 250Mbps per camera (settled on ~10-15fps per camera)
- Tried to reduce frame size but the cameras I have don't support binning or interleaving
- Tried implementing a ring acquisition as my understanding is that the acquire vi copied the image from the IMAQdx buffer to the IMAQ buffer whereas using a ring acquisition would allow me to access to image without copying the data. I couldn't do this because the none of the pixel formats are supported
- Optimise code to minimise CPU usage
It is this last point which is causing a noticeable problem at the moment. When my software, or something else, causing  more CPU utilisation the frames start getting corrupted. I am assuming this is because IMAQdx can't allocated enough resources to process the UDP datagrams quickly enough before the network card buffer overflows. I am only ever at ~25% CPU usage of 12 core machine though.
Specific questions I have:
- Is anything in my understanding of how IMAQdx works wrong/can anyone point me in the direction of some half decent documentation as to how it works
- Are there any other things I can look at altering which I haven't listed
- Is there a way of ensuring that the IMAQdx driver runs on its own thread so even if something else starts it still has the resources to process the UDP datagrams
(1,260 Views)
There's probably something wrong with your code.
Bill
CLD
(Mid-Level minion.)
(1,221 Views)
Can't help thinking that not using Jumbo frames is going to be a problem, but lets have some more info please.
Are you acquiring from the 3 cameras simultaneously? How big are the images?
Can you share some of your code - the acquisition part at least.
(1,203 Views)
