IMAQ1394 session in error
I have NIIMAQ1394 2.0.  When I recently upgraded from LabVIEW 8.2.1 to 8.5, I get a Session In error for all the 1394 VIs in IMAQ1394.dll.
Everything works fine in 8.2.1 and the camera still works when tested using MAX.  I am using Win XP.
(2,617 Views)
Hi Tom,
Thank you for posting to the NI Forums!  Try replacing the IMAQ 1394Init.vi from the Legacy palette. That is what crates the session ID, and is most likely the problem.  Once you replace that VI, the rest of the errors should go away because they all use the same session ID.
I hope this helps,
Maclean G.
Applications Engineering
(2,598 Views)
