12-07-2021 01:40 AM
I have an application built in LabVIEW 2021 64-bit that uses the IMAQ texture defect detection functionality. The VI runs fine in the development project. However, when the project is built into an executable, the application gives an error and the error out shows that the error is in the IMAQ texture defect detection. I am not sure why the same code runs without any issue when run from the project but does not run when built into an executable. Any suggestions for a potential solution? Note that switching to LabVIEW 32-bit is not an option for me. On addition note, I have checked the path for the loading of the classifier file to be correct and classifier file is read into the session correctly. Please let me know if there is a resolution. Thank you, AD.
Solved! Go to Solution.
12-07-2021 01:21 PM
Turned out to be a licensing issue. It seems that the VDM run-time license is also required to run the exe.
