IMAQ comparing images
Hi All
Im new using IMAQ, I need to do a simple test with an image,
I have a reference image and I want to compare it with an image taken by my microsoft webcam VX2000 to verify if both images are the same and pass a test, all drivers are installed, and all the IMAQ modules are installed too
Can someone help me with this..
(2,574 Views)
Tokyghy,
A good resource for you to check out will be our packaged examples that are shipped with LabVIEW and the Vision Development Module. In order to get your USB camera to interface with LabVIEW you’ll need our Vision Development Module that includes the IMAQdx driver which interfaces with USB camera. If you already have VDM, look at the examples in the NI Example finder. In LabVIEW, go to Help>>Find Examples and then Browse to Hardware Input and Output>>IMAQdx to find basic examples. To find pattern matching examples browse to Toolkits and Modules>>Vision. You can also go to www.ni.com and search for Image Pattern Matching and filter by Examples for LabVIEW examples and filter by KnowledgeBase for troubleshooting. I hope this information helps.
Blake C.
www.ni.com/support
(2,548 Views)
