07-17-2006 11:13 AM
07-18-2006 11:53 AM
Hi Terry,
I ran your program with your video and got error 1074395975 DirectX has timed out reading the avi file. I do not think there is anything wrong with your program because I ran your program with a different avi file and it worked perfectly. I also ran the shipping example Read AVI Example.vi with your video and got the same timeout error.
So there must be something wrong with your avi file. Perhaps frames 36 and 51 are missing or corrupt for some reason. Try creating the avi file again and see if you still have the same problem. If you do, then we'll have to investigate the problem with the creation of the file.
Christopher W.
Application Engineer
07-18-2006 12:26 PM
Hi Christopher,
This is an intermittent problem that is occuring. The video clip that I sent as an example is from a series of 12 clips that were taken. From this series, 3 clips are giving the same error. I am not sure how the avi file is written, but is the problem with the image or the frame data? Do you have any suggestions on how I should proceed with the diagnosis?
07-19-2006 04:52 PM
