IIR Filter-based Equalizer
I am trying to implement an audio equalizer in Labview and I found this example of a 4 band IIR Filter-based Equalizer:
http://zone.ni.com/devzone/cda/epd/p/id/5764
Which is perfect to get me started on the idea but the example given here is intended for Labview 8.5 and I am using Labview 8.0.
Is there a way to get this example to work in my version?
I think that just seeing the code without actually running it would suffice.
Thanks a lot for the help,
Orel
(2,716 Views)
Hi Orel,
   as stated on the web page you linked, this example is for LabView 8.5 AND LabVIEW Embedded Module for ADI Blackfin Processors.  If you don't have it, you won't be able to properly load this example.
   Of course, if you're building an application for LabView-Blackfin gear, it is tha right example, and you may ask someone who has these tools to downconvert it (if applicable....) to LV 8.0
graziano
(2,715 Views)
