IEWebBrowser2 & IE11
Hello everyone, I'm using the activeX IWEBBROWSER2 controller which natively uses IE7 even if IE11 is installed on the PC.
How can I use IE11 also from IWEBBROWSER2 within the labview development environment?
Thanks for your help 😉
(2,223 Views)
Are you sure that it's using IE7?  How are you checking to see what version is embedded?  I don't think it's possible to have two versions installed.
aputman
(2,211 Views)
