ICD file for SP5000M PCL Jai camera, with 1433 framegrabber
Hi everybody! It is been a long time without writting here!
I am wondering if anyone knows or has an icd file for the Jai camera SP5000M PCL. I've tried different ways to set it up, but I always get the FIFO overload halt error when I try to acquire the full window (2056x2048) with a 500x500 window it is apparently working fine at NI MAX, but i do not know which framerate.
I found one icd file in the forum and tried it but does not work, also generated one by myself, but I may be doing something wrong because it is not working neither.  I asked JAI but get no answer...
If you guys could help me to set the system up would be great 🙂
Thanks in advance
(1,039 Views)
Hey Magnetic,
I think you can try to use NI Camera File Generator
At least, you can try to find the solutin in the following article:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YI74CAG&l=ru-AM
(991 Views)
Thanks for your answer!
Yes I've tried to generate an icd camera file several times, but until now I just manage the full window at 30fps despite it is supposed to acquire at 130fps, any other configurations of the camera results in error. JAI support it is not helping at all because the say it is a NI problem as the frame rate needs to be set at the frame grabber, I am not sure if it is a comunication problem camera-framegrabber or just the system cannot manage so many data as the window it is quite big (2056x2048) and the system it is quite old. So far this are my result and I think we can live with this frame rate, but it is a pitty not being able to take advance of all the camera capacities.
(967 Views)
