I2C speed change
I am new to LabVIEW and new to this community. I run a simple project to get data from an I2C bus but found the speed to be 100KHz. Is there a property I can change to 400KHZ bus? Or this is the only option in LabVIEW to run at 100KHz. Thanks for your help in advance.
(2,295 Views)
Which device you were using?
Read this thread.
Thanks & Regards,
(2,260 Views)
