I2C Write/Read Test Case – Always Getting NACK (Need Help)
I am working on an I2C test case using LabVIEW + PXI Digital Pattern instruments, and I am consistently receiving NACK instead of ACK from the DUT. I want to share my complete setup and flow so the community can help identify what might be wrong or suggest better approaches.
🔧 Hardware Setup
PC (LabVIEW Application)
PXIe-1092 Chassis
  • Slot 3: PXIe-6571 (100 MHz Digital PPMU – used with Digital Pattern Editor)
Breakout Box
Device Under Test (DUT)
📌 Test Flow
1. Initialize Session
  • Provide the instrument name and slot for the PXIe-6571.
  • Initialize the Digital Pattern session.
2. Power ON the DUT
  • Supply voltage and current limits based on the DUT datasheet.
  • Configure the required pins in PPMU mode.
  • Apply the voltage to power up the DUT.
3. Stabilization Delay
  • Insert a small wait to allow the DUT to power up and stabilize.
4. Power Verification
  • Measure the voltage and current.
  • Confirm that the DUT is receiving the correct power (no drop or overload).
5. Load Test Resources
  • Load the Pin Map file.
  • Load Specification Levels.
  • Load Timing (I2C timing specifications).
  • Apply levels and timing to the session.
  • Load the Digital Pattern (.digipattern) file.
6. Create & Write Source Waveform
  • Use Create Source Waveform and Write Source Waveform to send dynamic data.
  • The waveform contains the I2C write data (Address + Register + Data).
7. Burst the Pattern
  • Execute the I2C Write pattern using Burst Pattern.
  • Enable capture on the 9th bit for ACK/NACK sampling.
8. Fetch Captured Data
  • Fetch the actual captured samples from the DUT.
  • Extract the 9th-bit samples to determine ACK/NACK.
  • Currently, I am receiving NACK for every transaction.
9. Sample Count
  • Read the number of samples captured.
  • Confirmed that the samples match the number of expected 9th bits.
    What I Need Help With
    1. Is there anything wrong or missing in my test flow?
    2. Does PXIe-6571 require a specific pull-up configuration for I2C?
    3. Could my pin-map or pattern timing be incorrect?
    4. Is there a better method to capture ACK/NACK?
      • Example: Capturing all vectors and parsing ACK bits later
    5. Any suggestions for debugging I2C using the Digital Pattern Editor?
      👉 If you know any other method or approach, please let me know!
(563 Views)
What is your goal? to do DUT register read/write over I2C using 657x?
SDC addon is simple to use out of the box
Santhosh
Soliton Technologies
(556 Views)
Hi Santhosh,
Yes, my goal is to perform DUT register read/write over I2C using the PXIe-6571 with the Digital Pattern Editor.
We are developing a protocol-validation setup, so we need to validate the DUT’s I2C behavior at the raw signal level using digital patterns, not higher-level drivers.
I am manually generating the full I2C sequence
(START → Slave Address + R/W → Register Address → Data → STOP) and capturing the ACK/NACK on the 9th bit.
The pattern bursts correctly, but I consistently receive NACK, so I want to understand:
  • Whether using Digital Pattern + source waveform is the correct approach for low-level I2C protocol validation, and
  • If there are better ways on 657x hardware to reliably capture the ACK/NACK
    (e.g., compares, full-vector capture, adjusting compare/sample timing, or any recommended practice for open-drain protocols).
Regarding SDC:
For this project we cannot use SDC, because we need full visibility and control of timing/patterns for protocol validation.
So we need to continue with manual pattern-based I2C generation.
Any suggestions or alternative methods would be very helpful.
Thanks!
(526 Views)
I have not used that card before but I have implemented i2c from first principles on a FPGA and I get the frustration.
First are you sure the UUT is NACKing? I would check your signal with a scope.
Secondly, check the timing of your NACK read, you might be reading immediately after the last bit and the UUT hasn’t responded yet. Try delaying the read by 1/2 a bit width, the i2c requires the read mid bit.
Thirdly, are you sure you are tri-stating or changing your output to an input before reading the NACK?
(507 Views)
@sanacdac wrote:
Hi Santhosh,
Regarding SDC:
Thanks!
If you're validating the protocol using 657x, we got the right software for you to skip your efforts and get the business done,
I2C Protocol Validation Suite | Soliton Technologies
Please share your details over direct message and I will pass on the info for a demo.
Santhosh
(485 Views)
