08-28-2007 02:12 PM
08-28-2007 02:30 PM
08-29-2007 01:22 PM
Dear Joseph,
As you sugest I tried the waveform chart. Yes, it worked as I wanted, but I got extra problems: The waveform flicks (I´ve already tried all update modes) and as the X scale is incrementing continuously, I´m afraid it is certainly going to hit its maximum value and it will cause an error (my acquisition don't stop). I don't know how to fix the Xscale (like 0 to 200).
Thank you for your help.
Celia.
08-29-2007 01:42 PM
08-29-2007 01:52 PM
Dear Joseph,
Thank you, as you sugested I tried the waveform chart and yes it worked as I wanted but now I have an extra problem: The waveform flicks (I´ve already tried all update options) . Do you have any sugestions?
I have an error message at last reply, so I tried again. The second problem I solved disabling X Scale in Visible items, so the waveform is being update but the Xscale is not being showed.
Thanks again,
Celia
08-29-2007 02:28 PM
You use the waveform chart as I want. Do you let the Xscale incrementing all day long? This is what I mean with flicking: The waveform is not stacked it is "shaking" on the chart. I noted that the chart is fast er than the graph.
I am sending my VI in attachment.
Celia
08-29-2007 03:38 PM
