I would like to insert column headers into a Write labview measurment file
I am looking for a simple way to add column headers to my saved data. I am working with dynamic data VIs and would like not to have to build several arrays to do this.
(3,499 Views)
See the attached VI, I think this is what you are looking for ... property node on a table, output of Build Table 2.vi, to which I feed a bunch of merged signals.
Certified LabVIEW Developer
NI-VLM Administrator
(3,488 Views)
Sounds similiar to this post
http://forums.ni.com/ni/board/message?board.id=170&message.id=204407&query.id=49611
You could open up your LVM files, manipulate the signals and write them back into your original file.
David
(3,482 Views)
Oops you replied to the thread in my previous post.
If you want to assign column names then I think you will need to do that as a waveform data type so that you can set the appropriate attributes.
I couldn't see any other way of doing it but that doesn't mean there isn't one.
David
Message Edited by David Crawford on 09-12-2006 10:53 PM
(3,473 Views)
