I would like to associate a boolean light with 3 values(2 booleans, and 1 integer), such that if either is true, it should switch the light on
How do i do this, i tried using or structures, but get complaints.
(2,515 Views)
Or structures are good for you, but the main problem is the condition for your integer value. In the attached example, you can see the light on if one of the booleans is on and the integer is different to 0. If you need a different integer condition, just change it.
(2,515 Views)
