I want to write chart data to file. LabView 7.1
I am monitoring the output voltage from a electronic circuit using LabView 7.1 and a DAQ card.
I have been able to view the output voltage using a Waveform Chart but i have been unsuccessful sending the data to a file. Only one data point gets saved each time.
I am using the "Write to Spreadsheet File .vi "
Could someone tell me what i am doing wrong?
Please see the program attached below.
(3,028 Views)
i created a small example how it work.
Basicly you have to create a shift register and a insert into array and thats it 🙂
Message Edited by Tristan on 04-26-2005 03:22 PM
(3,026 Views)
please be aware that running a loop like in this picture generates lots of data to write into a txt file. That's why i put a pause after each run.
(3,015 Views)
Thanks Tristan
(3,010 Views)
