I want to transfer data through the serial port in the same coding that hyperterminal uses. How can i do it?
The serial port seems to be working, and labview seems to be sending the data, but the problem is in which format does it send the data, because in hyperterminal i just input the string "JDX" and it sends it to my device, with labview it sends something but my device does not recognize it.
(2,559 Views)
> recognize it.
Hyperterminal adds the carriage return/line feed to the string which is
generated by the return key to send out the current line. LabVIEW simply
sends out what you tell it, so try to set the string to "Show \ Display"
format and add a \r or \n or \r\n to the command you want to send out.
Assumes of course that you set the right baudr
ate/bits/parity etc in
LabVIEW with the VISA property node, when opening the serial port.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,559 Views)
