08-22-2012 09:01 PM
I want to spatially rectify one image to another using a set of mutual control points. I have some Matlab code that will accomplish this but I want to use the Labview/IMAQ fucntions to accomplish it. I already have a VI that will generate the control points
Has any one run into sample code or any documentation that describs how this can be done?
08-22-2012
11:07 PM
- last edited on
09-06-2025
05:01 PM
by
Content Cleaner
Hi irfocus,
See these links:
http://www.ni.com/white-paper/3169/en
https://www.ni.com/docs/en-US/bundle/371007b/resource/371007b.pdf
Try to provide some more information,post the VI you already have etc:-
09-06-2012 07:43 PM
Thanks for the info. I haven't read through it all yet but will do so shortly. I looked through this stuff previously and only found the ability to rectify or translate an image to a defined mutual pattern. I can't do that because of the difference in camera technologies (visual versus thermal IR) I am using whereby a pattern in one image may not exist in its partner image. So I am trying to rectify to a user defined set of control points. although the math must be precisely the same in the translation, the user input is different. With the documentation you sent me I am hoping that one of these functions allows the input of a set of control points in place of a define pattern.
Any additional thoughts would be appreciated.
