I want to save the values of my rings in a csv file in 3 rows (each value in one row).
Hello guys,
I hope you are all well.
I want to save the values of my rings in a csv file in 3 rows (each value in one row) without using the Toolkit Report Generation.
I thought about saving it in one column but what I want to do is save each value in one row.
How can I do this please?
Thank you in advance.
Best regards
(1,640 Views)
Can you post an exemple of the file that you want to generate ?
I tried your code and I don't understand why it doesn't fit your needs.
Loïc
(1,611 Views)
Accepted by topic author Emilie_23
Add another build array and a transpose array to switch from column to row.
Besides, the buttons should be in Latching mode.
https://tmesystems.net/
(1,604 Views)
Hi ZYOng,
Thank you very much for your reply.That works what I want.
(1,574 Views)
