I want a flexible knob
Hii,
In my program i am having two knobs i want a help that as soon as i leave the knob the value must return to 0
this is the program which i had developed please see the code and modify according to my requirements.
Message 1 of 10
(3,685 Views)
try this
Message 2 of 10
(3,676 Views)
I would not use a CPU burner loop (with no wait, consuming 100% CPU) and I also would use local variables instead of value property nodes.
Just add a second loop that just waits doing nothing unless one of the controls is relased or stop is pressed. No change needed to your code at all.
(There is still a flaw in the case where you would move the mouse outside the control before releasing. In this case the control would not reset to zero. What is the purpose of your implementation?)
Message 3 of 10
(3,665 Views)
Thank You a Lot
Message 4 of 10
(3,663 Views)
I want to control a dc motor using a h bridge
Message 5 of 10
(3,662 Views)
@ altenbach
I also mean to implement it the way you did.Smiley Happy
what is the advantage of using local over value property.
Message 6 of 10
(3,652 Views)
can you ellaborate
Message 7 of 10
(3,634 Views)
@shankey wrote:
can you ellaborate
What post are you referring to? Elaborate on what?
Message 8 of 10
(3,614 Views)
Why don't you simply do the experiment to see what is more efficient? Here's a quick benchmark applications (posted here).
To understand the reason, see DFGray's answer here.
Message 9 of 10
(3,608 Views)
@ altenbach
indeed a great learning........
Thank you
Message 10 of 10
(3,577 Views)
