I want LabVIEW run-time installer to run by default
I want to install an EXE on a PC that doesnot have LV. I want that the run-time time installation takes place by default, without showing the user the installer screen. Is this possible?
(2,700 Views)
Yes this should be possible. After install, you can launch the run-time installer and pass it a command line argument which causes it to install in a silent mode. I am not sure what the command line argument is, but you should download the run-time engine and read the installation instructions. This should tell you all of the command line options.
(2,700 Views)
The LabVIEW 6.0.2 update has the following options. However, I don't know if the LV Run-Time engine has them as well.
The updater may be run with the following options:
/l -- to generate a log file. To use this option from the start menu type "\setup.exe /l c:\lv602updatelog.log"
/q -- for silent installations (no user prompts)
/m- suppresses mass compilation
(2,700 Views)
