I need more then the maximum amount of connector terminals
I have a subVI that has 32 items that needed to be wired to the connector (16 input 16 output)
However, the pattern with the most amount of terminals only has 28, I need four more.
Is there anyway to make a custom pattern for connector terminals?
Or I notice on property nodes, they sometimes can have a LOT of terminals, would that let me exceed the maximum labview is limiting me to
Or do I have to make global variables or something?
That could work for a couple but I'll still run out of room
Anyone have any suggestions??
-Confused-
(2,737 Views)
reconsider the function design if you find you need more than 16 IO.  Ideally you should have at most 8 + error IO, from my experience.  Consider clustering multiple inputs into logical groupings.  Its a good idea to typedef these clusters to make it easy for maintaining your application.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,735 Views)
Hi cutekitte...,
I fully agree with Paul.
Just some questions:
Have you ever seen a function (in any  kind of programming language) that uses more than 32 IO arguments???
And how do you want to wire more than 32 IO on a 32*32 pixel icon?
Message Edited by GerdW on 08-27-2008 08:58 PM
(2,708 Views)
