I need a vi to calculate crc8 from the Polynomial x8 + x7 + x6 + x4 + x2 + 1 (D5)
Hi there.
I need a vi to calculate crc8 from the polynomial x8 + x7 + x6 + x4 + x2 + 1.
Is it possible to find one that is ready for use?
I have found a one example of an 8 bit crc vi, but it is not using the specific polynomial that I need, and I don't know enough about crc to modify it...
Hope you can help.
Chuck.
Message 1 of 12
(9,381 Views)
What do you mean by crc vi ? Where did you find it in LabVIEW ?
What version of LV are you using ?
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 12
(9,371 Views)
I am using LabVIEW 8.20.
By crc vi I mean a vi that can calculate the crc (cyclic redundancy code) checksum byte from a hex-string or a byte array.
Message 3 of 12
(9,367 Views)
I did not find anything in LabVIEW, but I found a llb file in this forum that contains a vi for doing crc calculations.
I attached it to this message.
Message 4 of 12
(9,365 Views)
Hi!
   Once I had to calculate CCITT CRC-16, of polinomial x^16 + x^12 + x^5 + X^0, and I didn't find a vi.  So I decided to use a Formula Node, and translate a C-program which you can almost easily find for computing CRCs.
   If you want, I can post my code (both LabVIEW and C).
   You can use also Code Interface Node.  I just used Formula node because I'm more used to...
   The only problem is the optimization: I've an un-optimized C code.  If you need speed, you can use table-based C code, but I'm not familiar with it.
   Hope I can help you, please let me know how I can...
   Have a nice day!
graziano
Message 5 of 12
(9,364 Views)
Hi graziano.
I would love to see your code!
Speed is not critical as the crc calculation is only perfomed on a small amount of data and not very often.
Chuck.
Message 6 of 12
(9,361 Views)
I'm back in a minute!
Message 7 of 12
(9,354 Views)
Hi!
   This is my simple formula node, note that:
     CRC initial value is 0xFFFF (according to standard I'm using);
    The final result of computation must be bit-wise inverted (one's complement, also defined in the standard I'm using)
     The polynomial is inserted as 0x8408, which is (x^16 omitted....) + X^12 + x^5 + x^0, swapped (bit15 goes to bit 0, bit 14 to bit 1 ... bit 8 to bit 7...).
    As you know, there're many parameters in CRC calculation, inversion, initial register value, one's complement of the result or not....
    Have a nice day!
graziano
Message 8 of 12
(9,349 Views)
Just let me say taht Data_validation_functions.llb is quite interesting, Thanks for it, I'll check it!
graziano
PS.: I think that the CCITT crc function in Data_validation_functions.llb misses 0xFFFF initialization.... but I've to check.
Message 9 of 12
(9,345 Views)
I probably won't get to it today, but thanks for the file!
Crc is a pretty tricky subject...
Message 10 of 12
(9,342 Views)
