I need a solution for a lab view apllication and installer problem
do I need to install DSC runtime Engine on the host computer that i 'll run my executable on?!!!
I just need to deploy my libraries on the host computer, and I'm not using data or alarms logging.
every thing seems to be right here but Idon't know why it's working
I'm waiting for an answer
Mahmoud Alshair
Intelligent Systems Integrator ( ISI )
System Developer
Message 11 of 13
(1,204 Views)
Are you using an I/O server to bind your variables to tags on your OPC server or are you using any of the functionality of the DSC module? If so you would need the DSC runtime engine to deploy those variables. Otherwise variables are deployed by programmatically deploying the library of the main VI of your Application.
Let us know if you are using any of the functionality provided by the DSC module?
Mehak D.
Message 12 of 13
(1,188 Views)
Accepted by topic author M.Shair
Hi Mehak,
Thanx for your cooperation,
Yesterday finally I solved the problem which was I should not use any functionality or properties of the shared variables "Logging,Alarmin, describtion and security"
and the path of the invoke node " deploy library" should be correct and according to computer which you gonna install the executable.
Thanx
Mahmoud Alshair
System Developer
Message 13 of 13
(1,173 Views)
