I need a random x,y coord inside a circle of radius r
I need a random (x,y) coordinate inside of a circle of radius r centered at the origin (0,0).  Been bashing my brain out over it for days.
Thanks.
(3,353 Views)
Forgot to give you what version i was using, Labview 7.0
(3,351 Views)
Here's a crude example.  It takes a random X coordinate between 0 and radius, and generates a Y coord from there.
The best I can do as a vi is 7.1 ...  Sorry.
Message Edited by Day on 08-31-2006 04:17 PM
(3,348 Views)
A more natural solution would be (IMHO):
Ton (in 8 you can combine the r/theta XY conversion into one function)
Message Edited by TonP on 08-31-2006 10:49 PM
My LabVIEW Ideas
(3,336 Views)
First we need to know what you mean by "random". For example TonP's solution wil NOT give you a homogenous random distribution, but will give you more dense probabilities near the center. If you want a flat 2D distribution within the circle area, you need to do it differently.
The attached image shows the outcome of 10000 random tries for something similar to TonP's code (Left graph, upper code segment). An alternative approach is shown in the lower code, which gives a truly flat 2D distribution (right graph).
(In the above example, the radius was set to 2).
Message Edited by altenbach on 08-31-2006 02:50 PM
(3,330 Views)
