I have tried several times to run a simple exe on a remote machine from another networked machine. I have read confusing info, like LV Run Time Engine needs to be running for the exe to run. How do I initially run the RTE? I have attached my simple example. I keep getting an error that the server refuses the connection.
In both the .exe options and the test.vi options I have set the following;
I have checked all the boxes for the VI Server: Configuration,and set the port 3363
VI Server: TCP/IP Access: *, Allow Access
VI Server: Exported VIs: *, Allow Access
How does the security/remote settings of the remote PC impact the success of this?
Any information or examples is greatly appreciated;
Thanks.
