I have trying to create an array of gpib instructions.
The following is an example.
Time           instruction               X                  Y              Z
0 00:00:00,mot,v1_m1,-1492316.6919,-5204326.7860,3360431.4341,0,0,0,0,0,0,0,0,0,0,0
The problem is I can create the time format column array but putting in the string command instruction in the second column is giving me problems.
(2,481 Views)
With an array, you cannot mix data types. Instead of a 2D numeric array, create a 1D cluster array. A cluster can have elements of different data types.
(2,471 Views)
