I have this program that plots voltage over current, but my graph seems to be off. I need a linear function with a positive slope but I keep getting the inverse. Does someone know how to fix it?
(2,774 Views)
Your VI upload is missing your subVIs named "umm.vi" and "ohms law daq program V3".  Also we can't really run it without a DAQ of some sort to go along with that DAQ assistant.
Can you run it and post just the section of code that does the graphing that turns out wrong, along with a set of data saved as default values in the VI that produces an inverse result?
(2,767 Views)
