I have problems with a executable
I have 2 vi and use a global variables file. When I make the executable the vi that read the global file don't work. how can I make the executable?
(3,234 Views)
Hi
This is a known problem. When running an executable the file path needs to be "stripped" twice to get the directory the file is in (Compared to being stripped once when running the source code). I assume this is your problem. I am attaching a vi file to help you determine if your file is an executable.
Amiram
(3,222 Views)
Thanks Aminra but you have this file for labview 7?
(3,212 Views)
Attached is a jpg.
(3,202 Views)
