I have problems to open *.INT files created by LabView 4
Dear Sirs, I am in a problem, as I have results of my research in *.INT format,  for which I was using the LabView 4.0.,  and now, I cannot access and open those files. Can you please help me and give me some useful hints, how can I open and visualise those curves , and which software to use. Is there any possibility to open it, or save it in a different format which is more accessible by other software,  in advanced LabView version, and is it feasible that we upgrade our LabView, as we would need to open the *.INT files, but on the other hand also to continue our reseach into this electrophysiological field. Thank you
(3,688 Views)
Hi imarinko,
you should investigate the vi used for writing those *.int-files. Maybe you will find a load-routine in the old sources as well!
The *.int-extension is no standard LabView-file. Someone wrote a vi to write those files and had a intention to do so. Ask him/her for explanation on file format, sources and help!
Or attach those old sources here in the forum. Or attach (a not too big) snippet of such an *.int-file.
(3,677 Views)
