I have a warning after running modelname_main.vi, which is created at RT workshop of Matlab
SITsys RTFIFOCreate DBLA.vi
  Virtuelles Instrument
    - Die an der Position "C:\Programme\National Instruments\Shared\System\nbfifo.dll" erwartete externe Bibliothek wurde von "nbfifo.dll" geladen.
SITsys RTFIFOCreate U8A.vi
SITsys RTFIFODelete DBLA.vi
SITsys RTFIFODelete U8A.vi
SITsys RTFIFORead U8A.vi
SITsys RTFIFOWrite U8A.vi
The following warning appears. What is this?
Other question is,
I cannot stop the modelname_main.vi, which is created automatically by RT workshop. When I press the stop button nothing happens. Is it because of the above warning??
(2,823 Views)
I see from your message that you are using SIT 2.0. The current version, SIT 3.0, has many improvements which make it easier to use and more powerful. I encourage you to upgrade to SIT 3.0. Please look at the Simulation Interface Toolkit page for more information.
I also looked at the warning message which you posted. What this indicates is that the software was looking for a file called nbfifo.dll in the C:\Programme\National Instruments\Shared\System\ directory. However, it found that file in another directory. I do not believe that this is a problem, and I also do not think it is related to why the modelname_main.vi does not stop.
-Andrew
(2,814 Views)
