I have a flexlm license conflict with other software (codewarrior)
I have both LabVIEW and Codewarrior installed on this machine. It appears that they both use FlexLM license manager and it can't deal with the conflict. When I install LabVIEW, it causes Codewarrior to fail to operate correctly. I used a utility that came with Codewarrior called lmdiag.exe and it shows a license file name of C:\Program Files\National Instruments\Shared\License Manager\Licenses\LV_RemotePanelConnection.lic but it should show Codewarrior's license.dat file. Can I un-install LabVIEW and re-install without this remote panel connection feature and get it to not use FlexLM? Is there some way to get FlexLM to operate correctly with both LabVIEW and Codewarrior?
Message 1 of 8
(5,090 Views)
I am curious... I also have codewarrior installed, but I've never had a problem with Flexlm.
Which version of LV are you using?
Message 2 of 8
(5,087 Views)
This is LabVIEW 6.1 on WindowsXP Pro. I'm sure there is a way to get them both to cooperate but I don't know much about FlexLM.
Message 3 of 8
(5,080 Views)
Hey Powerwizard,
My initial guess of why this is occurring is LabVIEW may be changing a registry key that CodeWarrior is using to determine where the license file is located.  Could you post a screenshot from your registry of HKEY_LOCAL_MACHINE\SOFTWARE\FLEXlm License Manager and also HKEY_LOCAL_MACHINE\SOFTWARE\FLEXlm License Manager\NILM License Manager?
Pat P.
Software Engineer
Message 4 of 8
(5,057 Views)
Sorry for the slow reply. I thought Codewarrior support was going to fix this but I'm still having problems. They did give me a temporary license and I can now use Codewarrior and LabVIEW but if I try to use my "real" license for Codewarrior, it doesn't work.
Attached are the screenshots of the registry...
Thanks for your help.
-Dan White
Message 5 of 8
(5,033 Views)
Hey Dan,
I came across an article that I believe may help to resolve this issue.  This Knowledgebase talks about a situation where NI License Manager and another FlexLM application don't work properly together.  Check out this link.
Pat P.
Software Engineer
Message 6 of 8
(5,017 Views)
FWIW I've had extended and unresolved problems with FlexLM used by other products (SolidWorks, Fluent, Gambit).  I removed these products from my laptop, but later my new installation of NI's MAX wouldn't open unless the laptop was plugged into our network.  On a hunch, eliminating the user environment variable LM_LICENSE_FILE = ####@AAAAAAA in Control Panel > System > Advanced fixed the problem.  [this web site looks like it's formatting that variable value as a web site, underlined, but it's intended as plain text.]
This doesn't fix the OP request to make both programs work together, but maybe it's worthwhile as a diagnostic, or to others in my situation?
Message 7 of 8
(5,005 Views)
The knowledgebase link from Patrick P. solved the problem. Thank you very much Patrick!
Message 8 of 8
(4,998 Views)
