I get Compiler Error xc=0x53
I get a compiler error while programming in LabView 7.0, Windows 2000, the message indicates: "Compiler error. Report this problem to National Instruments Tech Support. genDRLoad bad type: xc=0x53."
Could you help me on this issue?
(2,500 Views)
I found the error: the problem is with element to search in the 1D array.  You have to change it to variant type with the VI "to variant".
(2,498 Views)
