03-18-2015 08:16 AM
Hi
I have a question and do not know why I did not coincide with the time that stores a data graph with the time at which the data is stored on the PC should be every 0.5s and there values are 0 almost, 46s between data and information.
Attached is a picture and -vi.
By the way why do not load the stage number and always reads 0?
Thanks for your help.
03-18-2015 08:17 AM
03-18-2015 10:37 AM
There are a lot of things wrong in your VI. You have no data dependency between your simulated signal source and the operations you do with it, you are offsetting the t0 using a constant timestamp, and you are using a local variable to append data to Table Control. I do not know why you have two tables at all.
However, to address your specific questions:
03-19-2015 06:31 AM
Hi Vltan.
I modified my vi.la simulation signal at 10 Hz and period 0.1s.
Where I have the problem is that when the pc was not increased in 0.1s.When the while loop period is 0.1s.
You can modify my vi.
03-19-2015 06:50 AM
Note that with the "Simulate acquisition timing" checked in the Simulate Signal Express VI, you do not need the Wait Until Next ms Multiple in your loop; the Simulate Signal is controlling timing itself.
The loop period is nominally 0.1 s, but it will not be very well controlled on a non-real-time target. Variations of several milliseconds are expected on a PC, with variations increasing more as depending on the amount of activity (more applications running, lots of GUI interaction and mouse movement, etc.).
03-19-2015 07:32 AM
When you use a PC's time to timestamp values directly, you are at the mercy of the update rate of the Windows/PC clock. I found that the update rate of that clock is about 1/60th of a second. The timestamps generally jump about 16-17 millisecond steps. You are probably seeing that effect here.
03-19-2015 12:09 PM
Sample 1 sec. an loop T = 1 saves the data well.
Sample 2 sec. an loop T = 0.5 saves the data well.
Sample 4 sec. an loop T = 0.2 saves the data well.
Sample 5 sec. an loop T = 0.25 saves the data well.
It is the problem of PC / Windows clock ?
