I cannot get a llbto build to a dll for use with C# and LabWindows CVI
I'm trying to build the tkdpo4K.llb into a dll for use with LabWindows CVI, Teststand and C#
Error generated:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 7 occurred at Invoke Node in ABAPI Dist Build App from LLB.vi->ABAPI Build Shared Lib With Old Proto2.vi->DBEP_Invoke_Build_Engine.vi->DBUIP_Build_Invoke.vi->DBUIP_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488:  Non-existent board.
Method Name: Build:Application
(3,446 Views)
Hi m.mcallister,
I have seen something similar that was caused by the location you are writing to. Are you using a network drive by any chance? Please let me know. Thanks!
Steven
(3,433 Views)
I'm trying to create this on my machines hard drive, but I am on a networked machine
(3,432 Views)
Hi m.mcallister,
Could you please let me know what version of LabVIEW you are using? Thanks!
Steven
(3,412 Views)
I'm using LabVIEW 8.2 Professional Development system running on Windows XP Professional 2000 service pack 2
(3,404 Views)
I've been reading different discussion forums and I know that this machine has had LabVIEW versions 7.0, 7.1, 8.0 and 8.2 installed, all the directories still exist. Maybe I've got some pointers to files that are misdirecting the app builder.
(3,399 Views)
Hi m.mcallister,
This may in fact be the case. Also, have you tried to do a mass compile? PLease let me know. Thanks!
Steven
(3,380 Views)
