I cannot change the format and precision of Z-axis back to floating with 0 digits in intensity graph!!! Is this a bug?
I am trying to use intensity graph in my program.  I just found that once I changed the format & precision of Z-axis, I could not change it back to floating point with 0 digits.  Is this a bug?  I didn't find previous discussion here.  I attached my VI.
(3,013 Views)
I'm not having that issue with LV 8.2.1
Have you tried using the Advanced editing mode of formatting the scale and maually plugging in "%.0f"?
2006 Ultimate LabVIEW G-eek.
(3,004 Views)
Thanks, Jonnie.  I just tried advance editing mode.  If I put %.1f, it is ok.  All the numbers have 1 digit.  If I put %.0f, I got warning (a red light on the right of format string).
By the way, I am using LV 8.2.
(2,998 Views)
This might be the bug fixed in 8.2.1 referenced as 40FC9LTX
from the bug list: http://digital.ni.com/public.nsf/allkb/CAB9E23506CA6A18862572B8001066C6
40FC9LTX Fixed an issue where a floating-point numeric control cannot show zero digits of precision.
Can anyone out there w/ 8.2 repeat the bug?
(2,992 Views)
I'm using 8.20, and can confirm the bug in numeric controls and indicators  Go to "format and precision" and select "advanced editing mode" on the numeric. "%.0f" shows as an invalid format, while "%.1f" is accepted.
A possible workaround is to use %d as the format, or if a string indicator can be used, use format into string with "%.0f" as the format string, which DOES work.
Rod.
(2,979 Views)
Thanks, Rod.  I appreciate your help.
(2,973 Views)
