I can use a littl help with this...
hello guys,
Im building a program in labview but i need some help...
the thing is, i got 3 buttons and 3 displays, if i press all buttons very shortly after eachoter, the butoon i pressed first, has to display a "1", the display i pressed 2nd has to display a "2" etc...
can you guys please help me with that cuz' i have only had to learn the labview basic lessons
regards Jeff
Message 1 of 20
(3,544 Views)
Hi Jeff
The attached vi might help you. It's very simple and there are better solutions (producer-consumer pattern). But as you say you just had to learn the basics, I assume this would be a little bit to much.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 20
(3,537 Views)
are you looking for something like this?
Message 3 of 20
(3,537 Views)
beckto, thanx for your VI it have helped me a little but its still not the one im looking for cuz' there are no displays in your VI but thanx anyway 🙂
Regards Nico
Message 4 of 20
(3,525 Views)
devchander, thanx for you VI but i cant open it... i only got LabVIEW 7.0 and yours is made in 7.1,can you please post it in version 7.0 :$
Regards Nico
Message 5 of 20
(3,524 Views)
Hi
I assume that you guys are students, because once "Nico" answered and "Jeff" asked the question.
According to this, it firstly does not make sense, to give you a complete solution, as you should learn somehting. Secondly, if the answer is not what you expected, you should maybe be a bit more precise in asking your question.
So if you say that there is no display - this could mean almost everything. A numeric or a text indicator, a graph and so on.
Thomas
Using LV8.0
Message 6 of 20
(3,523 Views)
Jeff is me and Nico is my projectpartner... we have got to make a project but we have only got basic lessons... thats the reason why we asked you guys to help us, otherwise our assignement would be a little to hard
Regards Jeff
Message 7 of 20
(3,518 Views)
Ok - but you still should be more precise. As I said - we will help, as long as we do not have code the whole project. But to help in a good way, we really should know what your goal is. Also referring to my previous post, "display" is a very general word.
Using LV8.0
Message 8 of 20
(3,515 Views)
here we go
regards
Dev
Message 9 of 20
(3,511 Views)
Hi Nico,
I agree with Thomas on his note about the clarity of queriees, if you put a question clearly, you will get a good answer.
all the best learning for LabVIEW.
regards
Dev
Message 10 of 20
(3,511 Views)
