I can´t open this file.vi
"labview load error code 8"  labview 5.1; 5.11, ...says .I can´t open this file  what happen ? could you be able to open it  ? If changes something  could you re-send me
(2,851 Views)
Because you don't have some vis, you should download all of the vis where you find this programme
(2,847 Views)
You will not be able to open this VI in LabVIEW 5.1 or 5.11 because it was last saved in LabVIEW version 7.0. It opens fine in version 7.0, 7.1, and 8.0.
(2,842 Views)
HI!
I can´t use my A.O contunuos gen .vi ; and neither their associates A.O.Group config.vi neither A.O buffer write.vi ¿what can happen? ; library .llb is completed  but it´s not go on.Could you send me an useful version of them? I have also the same version of Labview.
(2,711 Views)
Why did you post a new question to such an old thread? What exactly is the error that you get? Are you still using LabVIEW 5.1? What do you mean by library.llb is completed? The function you mention is part of traditional DAQ. You can find all of the versions available for download at http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C1293?opendocument&node=132070_US
I don't know for sure what's the latest version that supports 5.1 but I suspect 6.9.3.
(2,705 Views)
