I can't install Labview
Hi
I have one big problem with LabView. I have Windows 10 Home 64-bit and I can't install LabView. I tried to install a few versions of this program and my laptop always crashes when bar installation is on "Publishing Product Information".
I have to restart windows because evrything jams. Firefox, explorer or dektop.
I tried to install these versions:
http://search.ni.com/nisearch/app/main/p/ap/tech/lang/pl/pg/1/sn/n8:28,ssnav:pdl/  (evry)
http://www.ni.com/gate/gb/GB_EVALLVUSER/US
http://www.ni.com/gate/gb/GB_ACADEVALSOFTWARE/US
Labview (1.35GB), LabView for 64-bit systems, LabView in German.
http://www.ni.com/academic/download/archive/
I tried to install all versions 4 or 5 times in compliance with Windows 8, Windows 7 SP1, Windows 7, Windows Vista and Windows XP.
When I restart my laptop I have an application "National Software Instruments" in "Add or Remove Programs". But this application doesn't exist in my system. I have to uninstall this this application because it only makes my laptop slower.
Message 1 of 16
(8,668 Views)
I think LabVIEW 2015 is the only version (currently) that is supported on Windows 10.  Make sure you are installing LabVIEW 2015.
Message 2 of 16
(8,629 Views)
I am sure. It's always was LabView 2015
Message 3 of 16
(8,611 Views)
I think it installed just fine.  That is the only thing that is supposed to show up in "Programs and Features".  Open it up and you will see options to uninstall/repair LabVIEW.
I'm curious... did you even look to see if LabVIEW was in your Start Menu?
One more question: Why LabVIEW 64-bit?  Unless you are going to deal with such huge chunks of memory that the 4 GB absolute limit set by a 32-bit application is going to be an issue, it is better to stay with LabVIEW 32-bit for overall compatibility.
Bill
CLD
(Mid-Level minion.)
Message 4 of 16
(8,599 Views)
Just FYI - I use LV2013 on Windows 10 without any issues. Admittedly, it was installed before the upgrade so maybe the installation might fail but it certainly runs fine.
I also echo the statement from billko - unless you need the extra memory, you should probably use 32-bit LabVIEW.
(blog)
Message 5 of 16
(8,570 Views)
1. I have only: "Unistall/Change". This program doesn't exist in my disc, I find.
2. Nope.
3. I try 64-bit and 32-bit
Still nothing.
Labview2013 too crashers
Message 6 of 16
(8,547 Views)
Hello Kasztanek,
have you a clean W10 installation or an upgrade to W10?
Please look also here:
https://www.ni.com/en/shop/software-portfolio/national-instruments-product-compatibility-for-microso...
"Not supported" does not necessary mean, that it will not work, but I would not count on it...
B/R
Jozef Lipták
Message 7 of 16
(8,499 Views)
Are we still talking about LabVIEW not installing at all?  Or did you finally get it to install and now it's crashing when you try to use it?
Bill
CLD
(Mid-Level minion.)
Message 8 of 16
(8,468 Views)
Still talking about this: "I can't install LabviewN wersion X/Y"
I upgraded to Win10 from Win7.
I read evrything about my system and requirements, installed many drivers for this and still nothing.
I've been trying to install Labview for two weeks so please: don't treat me like an idiot.
Message 9 of 16
(8,442 Views)
The only version of LabVIEW for Windows 10 64 bit is LabVIEW 2015 (32 bit).
Here is a compatibility chart outlining the compatible versions of LabVIEW.
Windows Version Compatibility with LabVIEW
-Joe
Message 10 of 16
(8,421 Views)
