> I am running Windows 2000 and LabVIEW 6i which is some student version
> of LabVIEW. I have a AT-MIO-16E-10 DAQ card installed on this
> computer. MAX sees the DAQ and when I test it, everything works
> great. However, when I start a new VI, the Acquire Waveforms subVI
> will not work. There is one VI about 5 layers deep that says that the
> Code interface nodes and Call library function are not supported by
> this version of LabVIEW. Is there anything I can do to fix this
> problem? Please help!
It sounds like you are running the student edition which comes with a
textbook and doesn't support external code such as DLLs, CINs, or
ActiveX. You might want to check with others at your university and see
about getting access to an academic edition or a
full edition.
Greg McKaskle
