I am using a timed while loop and am unable to get the loop to run at a speed of less than 1ms (I am currently using the Wait(ms) function). How can I get a faster response?
I am trying to create a virtual engine within a timed while loop and am unable to get the loop to run at a speed of less than 1ms (I am currently using the Wait(ms) function). This does not however allow realistic engine speeds. How can I overcome this? I have access to a PCI-MIO-16E-4 board.
(3,061 Views)
andyt writes:
Andy,
Unless you use a real time platform, getting extactly 1 ms loop rate
(or even less) is impossible. It starts getting troublesome at about
0.1 Hz for standard operating systems.
I'd tackle your problem with "if i mod 10 == 0 then sleep 1 ms".
Of
course this is jerky by design.
HTH,
Johannes Nie?
(3,061 Views)
If you need fast, reliable loop rates, LabVIEW Real Time is definitely the way to go. You can find more information on this product at the following webpage: http://sine.ni.com/apps/we/nioc.vp?cid=3304〈=US
(3,061 Views)
