I am unable to print main VI due to "image.ccp"
I am abla to print sub VI but when try to print main Vi it says Failure:"image.ccp" line 11326.
(2,772 Views)
We have a web page that discusses why these errors occur and what you can do to fix them. Goto www.ni.com >> support >> labview >> LabVIEW Internal Errors (Failure in XXX.c) . The problem is that not all printer and video drivers are equal and sometimes they do not do what LabVIEW expects. The fix is to upgrade to the newest drivers and/or change the print settings.
Jeremy Braden
(2,773 Views)
Jeremy,
I think that there is more to it than this.  I have a test set that has been running essentially the same software for 2 years.  Win 2K, LV 7.1.  The print section of the program hasn't been changed.  A month ago we had this problem intermittently.  We updated the printer drivers, and changed to a different printer (different type) all to no effect.  A week or so later it mysteriously stopped.  Now the problem has returned.  If we select File>>Print Window  it will print OK.  I have tried both Print Panel.vi and Easy Print VI Panel or Documentation (string).vi.
Jim
Jim
LV 2020
(2,621 Views)
