I am unable to load labview for FTC onto a Vista PC.
I am unablle to load labview onto the pc.  I have the firewall turned off & cannot seem to find the issue.  In the beginning the error message read that there was a problem & I would be contacted if a solution was found.  I removed the program & I am now completely unable to load it at all.
(2,888 Views)
What's happening after you removed the program? Any error message when you launch LabVIEW? What version you are using?
Whether a system restart will help? Post back.
(2,886 Views)
By load LabVIEW are you referring to installation issues or is the install performed without issue?  If there are errors reported during install, please post either screenshots or the text from the error(s).
If the issue occurs when you attempt to open the LabVIEW executable, what is the specific error being reported?  Did LabVIEW run at some point prior to this problem?  Try renaming LabVIEW.ini (in \Program Files\National Instruments\LabVIEW x.x\) and then launch LabVIEW.exe; this will reset the config options for LabVIEW.
When you "removed the program" did you go through the Control Panel to properly uninstall the application?
-Bob
(2,870 Views)
