I am trying to read in an ascii file and output it onto a waveform graph...
After doing the Read From Spreadsheet, do a Delete From Array and remove column 5. You can see the extra column yourself if you open the Read From Spreadsheet and run it by itself. Can you clarify this. Thank You.
Message 31 of 31
(366 Views)
