m that I am having is that to do this I need to fill two different structures, one containing a pointer to a double, which I don't think I can do without perhaps a wrapper function. The biggest problem is that I don't know how to even go about doing this.I have two structures that I need to fill in order to read a block of data from a given DLL which are
typedef struct CHBL_ORDER_T {
INT32 lBlock; // block number, set by user (typical 0)
INT16 sChan; // channel number, set by user
UINT16 usFlags; // only DATA_1OFN at the moment
INT32 lChSR; // channel sampling rate, returned by open
INT32 lFirstMP; // BSR MP not greater than "open sta
rt"
INT32 lBuffLen; // required CHSR based buffer size
INT32 lIncr; // distance between two buffered values
UINT16 usMask; // Mask used before Shift
INT8 chShift; // number of right shifts
} CHBL_ORDER, *PCHBL_ORDER;
typedef struct CHBL_FETCH_T {
double *pdblMin; // min or 1 of n array
double *pdblMax; // max array (either solo or along with MINMAX
INT32 lPos; // (set by user), returned by fetch
INT32 lNum; // (set by user), returned by fetch
} CHBL_FETCH, *PCHBL_FETCH;
I am trying to do the data block access with labview on page 18 of the attached pdf document.
I also have a c code exapmle attached in the zip file, the function in c i am trying to do is in Sample2Dlg.cpp
if anyone can help me out I would greatly appreciate it.
