08-01-2023 04:31 PM
I am trying to get a signal from the Spectrometer where I can do phase acquisition of fringes, and do Fourier transform of the spectral domain to the time domain. I want to do live measurements of the stability of spectral fringes. kindly explain to me the way to get data from Spectrometer using USB. Kindly attach some VIs if possible. Also suggest, which version of NI-Visa and Ni-DAQ works well with LabView 2020. I am using the spectrometer Avaspec NIR512-2.5 HSC-EVO from Avantes.
08-01-2023 08:48 PM
DS-Spec-AvaSpec-NIR256512-1.7-HSC-EVO-27012021 supports communication interfaces of USB3.0 high speed, 5 Gbps, Gigabit Ethernet 1 Gbps. You cannot use a DAQ device to communicate with it. You should reach out to their technical support to see if they have LabVIEW VIs or driver.
08-02-2023 04:49 PM
It looks like they offer a DLL, as well as some LabVIEW examples using it.
https://www.avantes.com/products/software/interface-packages-and-libraries-for-windows-and-linux/
