I am not being able to acquire data that the ECU requires a request for!!!! Any help/tips on how to solve this problem would be greatly appreciated.
I am using j1939. dbc file. I have a CAN card 9862 that connects to the ECU on the tractor. I am using examples provided Labview J1939 Frame output stream to send out data and J1939 Frame input stream to see the data.
When I'm running both VI. I get so many data and I can't tell which one is the one that I requested. Also, I am using bus monitor on NI-MAX to look at the data. I cannot tell which one is the one I requested either on the bus monitor because it is showing so many data. The bus monitor is not showing me the name of the data I want. For instance, I want to request data names hours (see attached file). When I use 00FEE5 as the identifier, I am not getting anything back. Also, I am using 254 as my node address.
Can someone please help?
(2,324 Views)
Hi GRC,
which attachments are you talking about?
  • On an ECU CAN bus there are a lot of messages available. Usually I filter them by their ArbID…
  • When you request for "data names hours" then you probably want to get a certain signal. All signals are transferred in messages, and you need to read/filter the messages by their ArbIDs…
  • The bus monitor usually just shows the messages sent on the CAN bus…
Can you attach your DBC file?
(2,285 Views)
Thanks GerdW for the suggestion. NI won't let me attach a dbc file. It says "the file type is not supported."
If you have an e-mail address, I can try to send it to you. However, I attached the information of the data "Hours" that I would like to request.
(2,250 Views)
You can attach the file if you zip it up and attach the zip file.  (Note: an actual zip file,  not .rar. not .7zip, not anything that would require someone to download an extra application besides what is already built into Windows in order to unzip it.)
(2,237 Views)
