I am not able to link proper speed values with the speedometer
I am not able to link proper speed values with the speedometer. It starts from 0 but there should be a 10 line which is not present , due to which the minimum and maximum values are not matching?? How to make the changes in the speedometer ?
(2,439 Views)
You need to do more work customizing your control so that the position for 0 is lower than it is now, until 10 lines up with your first mark and 250 lines up with your last mark.
See attached.
(2,424 Views)
Thanks!
(2,394 Views)
